edit: think I figured it out; was using the buttons in the original post but it seems that they also have a line that needs updating!
edit2: it is working now. for those people that come in the future and are mystified; check that both the buttons and the ColumnExifTool.js.txt have the correct path. so in my case, my exiftool paths are above & in the js.txt I've made it:
// -- Adjust to your system. Copy the path to exiftool.exe with 'Edit - Copy Other - Copy Full Pathnames (Double Backslashes)'
var exeExifTool = fsu.Resolve('C:\\exiftool\\exiftool.exe');
// -- Adjust to your preferences. Use double backslashes.
var cacheFolder = fsu.Resolve('/profile\\ExifToolCache');
thanks! I'm not sure if it was different, but i changed it to var cacheFolder = fsu.Resolve('/profile\\ExifToolCache'); ; still fails bc of missing exiftool.
edit: ahh, I see the issue maybe; I was using your buttons above "Generate Exiftool Helper Files" so I could try to see what I was doing wrong, but I see that the buttons also have a var exeExifTool = fsu.Resolve('/bin\\exiftool\\exiftool.exe'); which I'd guess has to be resolved as well
I worked several hours learning to use this script today.
I'm still on the original version you posted, but I'll get it up to date soon.
I would have done this much sooner had I known what I know now.
One thing I would want to change is to have the Field of View displayed in radians rather than degrees and as a fraction of pi with a fixed reducible denominator.
Well, I need start learning Jscript.
Thanks very much !
... the current version from February lets you easily do this, starting line 382.
Here, it just prints "Enumerating ..." writes the -Tags file and ... nothing more.
Also, I don't have the possibility to select some exif-made columns, unless I am missing something.
Great upgrade !
Thankyou, your efforts are appreciated.
I had no trouble at all getting my normal photo columns working.
The new script did them out of the box. All I had to do was change the ExifTool.exe path and with the new configuration button, double \s were no longer needed.
I know I'll make some changes and also revisit my old buttons I used with the older versions of this script. But it made my morning that it worked so well out of the box !
Yes. The cache is now written using the printConv option. From ExifTool's help:
-n (--printConv)
Disable print conversion for all tags. By default, extracted values
are converted to a more human-readable format, but the -n option
disables this conversion, revealing the machine-readable values.
If you prefer the previous style, remove the option from the script (line 194):
Replace
argFile.Write('--printConv\n' +
with
argFile.Write('' +
I'll add this to the configuration in the next version
Thanks !
I had it changed to my liking in five minutes.
Good thing, it was a blizzard here last night.
Now I have to clear a foot of snow and make paths for my dog.
