A true god amongst men... excellent script!
Here is my example of the fruits of your hard labor - a single button to offer all the options for Expandable Folders. It could not have been done without your script!
There are two versions with the same functionality but in different formats.
Version 8
Expanded Folders Options 3 Button Collapse to Parent with RMB.dcf (4.7 KB)
Expanded Folders Options Menu.dcf (4.0 KB)
Update v1.2.0 Beta 1 (2024-02-08):
- Now when expanding only the top level, a new thread is not initiated.
- Added
SELECT
andSELECT=dirs
, which allows to select the files/dirs whose parents are the newly expanded folders.
I got the idea from seeing jinsight's button, which seems to want to select the newly appeared items resulting from the recent folder expansion. Seems something useful to have at hand.
Now you can use SELECT
along with EXPAND
or TOGGLE
, to select all the files or just the dirs (using SELECT=dirs
Test it and let me know how it goes.
Updated main post with v1.2.1, which contains all the changes introduced in the latest beta.
I also updated the description for arguments, and added some new examples.
v1.3.0 (Feb 22, 2024):
If you are using a previous version, is highly recommended to update to this one.
COLLAPSE
has a new value :levels
, to effectively collapse all the expanded folders in all levels.- Added
colparent
andcollevels
values forTOGGLE
, to enable the corresponding values for collapse. - A problem with the custom progress dialog that interfered with other listers/windows, minimizing/bringing them to the front, has been fixed.
sorry, can't confirm working COLLAPSE=levels
or TOGGLE=collevels
option. can you give a small gif with all them collapsed. i've got only upper level collapsed
It is working. But keep in mind that wildcards are used to identify folders, so if there is a matching higher level folder, it is collapsed without collapsing their child expanded folders.
Without levels
With levels
Does not collapse all levels
I expected that "ExpandFolders TOGGLE=collevels" would collapse all the expanded folders in all levels. My test folder is at the top level within the file display lister.
Does collapse all levels
ExpandFolders COLLAPSE=parent,levels
can i toggle select
with your beatiful code =return "ExpandFolders EXPAND" + (KeyDown("shift") ? "" : "=top") + (KeyDown("ctrl") ? " SELECT" : "");
? and add collapse
here?
@jinsight @fkast you were right! levels
was not working if there's something selected. Can you try this version to know if it is working now?
ExpandFolders.opusscriptinstall (5.0 KB)
Thanks!
I'm not quite understanding what you mean here. Are you saying you want to create a similar button but for collapse
SELECT
doesn't work with COLLAPSE
I have five different buttons with this script and I am not completely satisfied with any of them. the code above is the closest to what I want, except TOGGLE=select
and for ex. alt-pressed COLLAPSE
. i need all in one button))))))))))
can't confirm. with ExpandFolders TOGGLE=collevels
i've got only upper level collapsed.
I don't think you can fit everything into a single button . But you can try it; I'm not sure how good the Alt modifier works on buttons.
My guess is that there are lower-level folders with the same name as the higher-level ones.
Can you send me a similar capture but with debug=ALL and showing the Scripts log?
You can send me via message if you like.
At least can you add toggle select
SELECT
acts as a toggle, you can pass that argument along with COLLAPSE
, it will be ignored.
here as a toggle (i.e. select/select none) ???
not for me))) sorry... it only expands and selects one next level with second-third ctrl key
That's not related with the command itself, but the code basically says:
default : ExpandFolders EXPAND=top
with shift : ExpandFolders EXPAND
with ctrl : ExpandFolders EXPAND=top SELECT
with shift+ctrl : ExpandFolders EXPAND SELECT
That's pure Evaluator in action.
New version 1.3.1 does NOT collapse all levels
Does collapse all levels where either the parent or a subfolder or a file under the parent is selected
I would like this effect available under the toggle option.
Thank you so much for all your efforts!
