Expandable folders and grouping
Hello,
Just switched to Dopus 13, mainly because of the expandable folders feature.
Unfortunately, this function is no longer available once grouping has been activated in a lister. Why is that? Is there a technical limitation that prevents the simultaneous activation of expandable folders and grouping?
TIA.
The two things physically/conceptually conflict with each other. Expanded folders are already grouping the file display by location.
Multi-column sort is still possible, however, and lets you keep similar items together below each sub-folder, without the group dividers splitting things up.
Got it.
I would love to see this in the future. As well as subgrouping. just about every aspect of Dopus is customizable, so it feels somewhat arbitrary for folder expansion to be disabled by grouping. I'd expect to just see all the contents of the folder in the same way as when grouping is off.
@Leo This is indeed a very necessary function. For instance, grouping by time does not affect the expansion of folders!
How would you group by time and group by folder at the same time? What would the groups be?
