The filetype has the NeverShowExt flag set (in the registry), which tells Explorer to do that. (Opus itself ignores the flag and always shows you file extensions unless you've turned them off entirely.)
I guess this is done so you can create .dcf files on your desktop and have icons you can double-click to run those commands, without the .dcf being part of their labels.
