Does anyone know if it's possible to sort files by date in the manner of Windows Explorer? Directory Opus sorts the modified date with directories first, then files. Windows explorer just sorts by modified date regardless of the object type. Thanks!
There are two options in the Folder Format dialog that can cause folders to get sorted separately to files:
