Export from 32bit, import in 64bit?
Hi,
I'm currently trialing the Windows 7 64bit version.
Should there be problems when I import the configuration in Win7 64bit which was exported from the Win XP 32bit partition ?
Any things we need to look out for ?
Thanks.
The only problem will be things like buttons which run 32-bit programs under "C:\Program Files" which are under "C:\Program Files (x86)" on a 64-bit system.
As long as it is only with button shortcuts, I can live with that.
Hopefully it does not screw the bare DO settings.
Thanks Leo.
Just an update that anything barebone DO runs perfectly fine after being imported in an x64 version. Just needs some updating in the Favorites and Folder Colors, and some paths in button codes.
