Express Dual Fine Small (Full dark/light mode Icon Set)
A redo of Express Dual - Icons - Directory Opus Resource Centre (dopus.com).
Took some tips from @skinz (many thanks) and these ones are mostly done by hand in Photoshop, they are clearer and sharper and there is more of them.
Learnt a bit about the differences between Anti-Aliasing, Blurring and Sub-Pixel Rendering.
enjoy :slight_smile:
(hero image by Microsoft Edge Image Creator)
  • A Dual Mode Iconset.
  • 26px and 22px
  • Needs Directory Opus 13.
  • 451 icons.
  • Move to the top of the icon list in preferences to replace all icons.
Made with Iconset Maker Pixel Perfect (Updated) - Icons - Directory Opus Resource Centre (dopus.com)
Updated
Thanks a lot, @galaxyhub, for these beautiful icons! :slight_smile:
I found a small issue when parsing the xml file with my own script: In the first line it says "encoding=UTF-8", but the file appears to be encoded in UTF-16 (as confirmed by opening it in Notepad++). I changed that line and everything worked. Perhaps an issue with the Iconset Maker?
Many thanks, have corrected the above iconset and both the Iconset Maker scripts.
