That doesn't work:
/dopusdata\Scripts\NirCmd.exe mutesysvolume 0
Executing from DOS works, DO ignores the parameters. Why?
That doesn't work:
Try putting the path in quotes, since it will contain spaces.
"/dopusdata\Scripts\NirCmd.exe" mutesysvolume 0
(Works fine here.)
Already tried this - nothing! Neither as usercommand nor as direct button or using full path.
Also I have other DOS commands working without quotes using dopusdata.
Strange.
Edit: Grmpf, the "mutesysvolume 0" doesn't work
! Just mode 1 and 2 (now set to 2 - toggle)!!! And also now it works without quotes like all other similar commands
Is the button set to Standard Function or MS-DOS Batch Function?
Both work for me, but try Standard Function if you haven't already.
(If it only fails in MS-DOS mode, are there any non-ASCII characters in your username which might be confusing DOS? (Assuming your /dopusdata dir is below your user profile.))
