if i drop the same .pdfs into the image compare it errors out, so maybe not
and\or completely different pdfs it only shows the differences in text so ima say, no it it cant do that
and found this under file formats for .pdf
Compares the text contents of Adobe PDF documents.
Uses freeware converter, Xpdf:
XpdfReader
Can't convert PDF documents which are actually pictures of text.
Can't convert PDF documents which disallow copying text.
bytim
November 2, 2024, 2:02pm
42
I add beyond compare 5.
script:
ExternalCompare.osp (103.4 KB)
button:
Beyond Compare 5.dcf (1.1 KB)
i recently discovered, and i am liking, ExamDiff , there a handful of bell and whistles that Beyond Compare doesn't. eg, it counts and tallies the differences in a file by type and outputs this info for you. and full paths option in title bar, etc.
an no fuss syntax highlight! for some reason I've never been able to get this work in BC
its not in this list
could it be added possibly??
thanks
X
ps...
i making my own button in the meantime and noticed this in their setup\program files, they use the version number in the dir name..
C:\Program Files\ExamDiff Pro 16.0 is the current stable
C:\Program Files\ExamDiff Pro 17.0 is the current beta
the registary HKEY_LOCAL_MACHINE\SOFTWARE\Classes\examdiff\shell\open\command they use shortname styling.. C:\PROGRA~1\EXAMDI~2.0\ExamDiff.exe "%1"
with a url protocol
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\examdiff]
@="URL:examdiff"
Here is a three button button to access ExamDiff features:
ExamDiff).dcf (1.4 KB)
Here is an icon:
