"Extra Line Spacing" in Details and Power mode
Hi,
I have a strange feeling that there is something wrong with that option.
In Details mode it is 0 (zero) and in Power mode it is 2.
Whenever I switch between these modes the line spacing is unchanged - I mean it is the same for both modes 0 or 2 - looks like one is affecting the other.
There is also a difference in spacing between the lines if I do this:
  • activate that option
  • write 0 in the Extra Line Spacing value box
  • click Apply
or
  • leave value of 0 in that box
  • deactivate Extra Line Spacing
  • click Apply
both should give same result but the second one makes spacing smaller than value 0.
Thanks
Confirmed, and fixed for the next update.
Until then, you can get the line spacing to take effect by switching to another mode between the Details/Power mode switch. e.g. Details->List->Power.
I can confirm - it is fixed in 12.2.5
Thank you.
