Extract archives to current folder on double-click
Is it possible: double click on a rar or zip file -> auto extract in the same folder as the file?
Hello and thank you for the help!
Replace Go with
Copy EXTRACT=sub HERE WHENEXISTS=rename
Can be done globally for all archives via File Type Groups or individually via extension.
Keep in mind that .iso files are archives, too :wink:
To limit this command to .rar and .zip files, add it to these two extensions.
I would suggest to use a modifier along with it, like I've done for myself. Otherwise just opening an archive is only possible via right click menu.
I made myself keyboard shortcuts for that, then you have more flexibility.
Thx you very much for your help!
Do you know what I have to add to delete the archive file after the unzip (without error), please?
You could add Delete, but there's no error checking. This topic gets discussed here at length:
Too much effort, for my taste. I'd either do it manually or use WinRAR's built-in delete functionality.
Revealing what OPs workflow is, it's not a DO "issue", he would be better suited with a program called "ExtractNow" (www.extractnow.com).
Thx for all the answer! Extractnow works great!
