jimerb
#1
I have many files that follow a very consistent format and it would be great if i could turn those fields into columns so i could sort them better.
The format is:
collectionname.yy.mm.dd.title.resolution.creator
For example
boats.20.12.22.sail.boat.1080p.fred.mp4
Is it possible to create thse columns?
- collectionname
- yy
- mm
- dd
- title
- resolution
- creator
And obviously i'd have another column with the same name so that If a file didn't match the format I could work with it normally.
Leo
#2
You can do it using these add-ins:
