Hi, is it possible with Directory Opus, to extract files from ISO images?
I use the terrific buttons Steve set up to mount and unmount ISO images using Daemon Tools to do this quite frequently. See [Daemon Tools).
In the same post Sasa also added the code to set this via the context menu using the .iso as a filetype.
It looks like it would be pretty easy to use this as a starting point to set up "automatic" extraction if that's what you're looking for.
Thank you. I have heard of people having crashed their system (no more able to boot) with the installation of the Daemon Tools driver.
I haven't had any trouble with it, but I understand the concern.
I think that there are similar posts under "Buttons & Toolbars" for Nero, Alcohol 120, etc., so you might see if you can find something there...
Good luck!
