Extracting WinRAR not through temp
When I drag and drop an archive from WinRAR-window to DO, WinRAR first extracts to a temp-folder and then DO copies files from temp-folder to final destination.
Is there any setting to avoid this and extracting files directly (note: only happens on drag and drop)?
From what I remember, if you drag & drop from WinRAR to something else, WinRAR creates the files in temp and then drops the temp files on the other application. By the time Opus is involved, the files are already in the temp dir.
AFAIK the only ways to avoid the temp dir is to use Opus instead of WinRAR (drag & drop won't go via temp), or to do the extraction entirely in WinRAR (i.e. without drag & drop).
Ok, normally I extract via DO/context, but sometimes I open an archive in WinRAR and then - in workflow - just drag it to DO... and then realize, that I have to wait twice a time :frowning:
