Fails on data transfers from phone to PC
I've been using Directory Opus to transfer files to and from my Android phone. In most cases I use FTP mode with the File Expert app running on the phone. I just tried using Directory Opus to transfer a folder containing 494 files over the USB interface. It keeps failing after awhile with an error message 30 saying it couldn't read a file. Clicking Retry doesn't help. The curious thing is that there is no problem reading all 494 files in FTP mode. The USB is much faster so I was really hoping to have this option.
Pete
Most Android devices support normal USB-connection (on connect you can choose to use internal SD-card as normal device like USB-Stick). What device we are talking about?
