Favourite folder does not expand when default lister is opened
I am struggling to understand the steps to be able to save an expanded view of my folders in the tree folders. I have a view that I like, then I save the default lister. When I exit and then reenter Dopus, the folder tree is not expanded as it was when I saved. I don't understand the interplay between Lister and Layout and saving and retaining a view. Is there a simple place this is explained that someone can point me to?
Saving the default lister is all that is normally needed.
Make sure Preferences / Folder Tree / Expand/Collapse / Collapse non-selected branches isn't turned on, as that would collapse the branch.
Hi Leo,
I've checked this and it looks fine but my folders are still collapsed when I reopen my default lister.
Here's what the setup looks like for Expanded/Collapsed:
I would greatly appreciate some other ideas for getting this to work or things to check.
Turn off the Only remember if pinned option shown in that screenshot.
Many thanks. That worked !!!!
