Feature Request: ColorPicker control for Dopus Dialogs
Would it be possible to consider adding a color picker in the controls one can add to a custom dialog used in scripts ?
One behaving the same as the one used everywhere in Preferences set-up for instance :grinning:.
Thanks in advance for answering about "absolute" feasibility, and also if this is something that has a chance to be considered at some point.
Certainly something we can look at.
Support for this will be in 13.7.1 (probably out next week).
Many thanks for this addition to Directory Opus with a very fast delivery (less than a month between request and delivery !!!), and a well thought set-up (I like the four different types of palette control).
I don't think of many other software where such a thing would be possible (and I know many where things are a lot worse , e.g. waiting MONTHS before a critical bug fix).
Great !!! :+1: :+1: :+1: :+1:
