File display not fully updated after Evaluator Function
I used this code to try out Opus 13.19.3 new Evaluator Function button:
for (i = 0; i < 10; i++) {
	Run("CreateFolder NAME=" + i);
It runs fine (and fast :+1: ) with a few quirks:
  • After the code has finished, only the last 40-60% of the created folders are selected.
  • Occasionally, the sort order is slightly incorrect
  • Occasionally, all folders are displayed, but vanish after a second
Everything will be okay after a refresh.
10 new folders (Selection)
50 new folders (Selection+Sort order)
100 new folders (Selection+Sort order)
100 new folders (Folders missing)
It seems to be because it's running asynchronously:
	Run("dopusrt /argsmsgbox " + i);
One-time execution:
function OnClick(clickData)
		cmd.AddLine('dopusrt /argsmsgbox ' + i);
	cmd.Run()
Yes it is, bug in the command parsing. If you supply a second arg (even an empty string) it should behave better.
Will improve further next update.
