It seems that the file operation dialog was no longer displayed during the beta version, I only noticed it now because I wanted to cancel the copy. I looked at the settings and it doesn't seem to be relevant.
If I exit Opus, the file operation dialog will be visible.
Opus 13.1
Are you using Active Window Manager or anything like that which moves/resizes/on-tops other program's dialogs?
If so, try uninstalling it. Many of those tools cause problems with our progress dialogs for some reason.
I only have Listary and some AutoHotkey scripts that just inspect the windows and won't operate on Opus.
If I uncheck the script that uses WatchTab
, the file operation dialog comes back. The problem seems to come from Opus.
// EventUpdateVar-ADS
// (c) 2022 Ken
// This is a script for Directory Opus.
// See https://www.gpsoft.com.au/DScripts/redirect.asp?page=scripts for development information.
// Called by Directory Opus to initialize the script
function OnInit(initData)
initData.name = "EventUpdateVar-ADS";
initData.version = "1.1.5(23.11.14)";
initData.copyright = "(c) 2022 Ken";
initData.url = "https://resource.dopus.com/t/set-tags-add-tags-by-list-beta/43269/2";
initData.desc = "Display ADS in the Status Bar. \r\nFor Preferences / Display / Status Bar: ADS={var:lst:ADS}";
initData.min_version = "12.0";
function OnAddCommands(addCmdData)
cmd.name = "UpdateVarADS";
cmd.method = "OnUpdateVarADS";
cmd.desc = "EventUpdateVar-ADS";
cmd.label = "UpdateVarADS";
cmd.template = "";
cmd.hide = false;
cmd.icon = 'script';
function OnUpdateVarADS(scriptCmdData)
var tab = scriptCmdData.func.sourcetab;
//var lister = tab.lister;
var lister = DOpus.Listers(0);
if (!tab || lister.Vars.Exists("UpdateVarADS")) return
lister.Vars.Set("UpdateVarADS") = 1;
var dlg = scriptCmdData.func.Dlg();
var cmd = scriptCmdData.func.command;
dlg.detach = true;
dlg.template = "dialog1";
dlg.title = "OnSelect";
dlg.top = false;
dlg.create();
//dlg.show();
dlg.opacity = 0; // Make the dialog invisible
dlg.watchtab(tab, "select,activate,srcdst"); // Watch events
var msg;
do
msg = dlg.GetMsg();
var msgResult = msg.result;
if (!msgResult)
break;
var value = msg.value;
var event = msg.event;
var ctrl = msg.control;
var dt = msg.data;
DOpus.Output("Event: " + event + ", Value: " + value + " ctrl: " + ctrl + " data:" + dt);
if (value == "select") // If there is a select event
tab.Update();
if (tab.Selected.count > 0)
var fsu = DOpus.fsutil;
var ADSfile = tab.Selected(0).realpath + ":Tags"; // ADSfile
// If ADSfile exists
if (fsu.Exists(ADSfile)) {
var ST = DOpus.Create.StringTools();
var openText = fsu.OpenFile(ADSfile, "r"); // Read ADSfile
var text = openText.Read();
openText.Close;
var textbom = ST.Decode(text, "utf-8 bom"); // Decode as UTF-8 with BOM
var myArray = textbom.split("\r\n"); // The separator is \r\n
var ADS = myArray[0]; // Get the first line
} else {var ADS = "";}
lister.Vars.Set('ADS', ADS);
else
lister.Vars.Set('ADS') = "";
cmd.UpdateToggle(); // Refresh
} else if (value == "activate" || value == "srcdst") {
lister.Update();
var tab = lister.activetab;
if (!tab) var tab = DOpus.listers.lastactive.activetab;
try {
} catch (error) {break}
} else if (value == "close") {
lister.Update();
if (!lister.lastactive)
break
while (msg); // msg loop
if (lister.Vars) lister.Vars.Delete("UpdateVarADS");
var cmd = DOpus.Create().Command();
// Called when a tab is activated
function OnActivateTab(activateTabData)
cmd.RunCommand('UpdateVarADS');
// Called when a Lister is activated
function OnActivateLister(activateListerData)
==SCRIPT RESOURCES
<resources>
<resource name="dialog1" type="dialog">
<dialog fontsize="8" height="14" lang="english" opacity="0" width="54">
<control close="0" height="14" name="button1" title="Exit" type="button" width="54" x="0" y="0" />
</dialog>
</resource>
</resources>
Ah, very strange. Thanks for those details!
It's possible the hidden WatchTab window is being chosen as the dialog parent, maybe. We'll investigate.
@WKen does it make any difference if you change this line:
for this one?
var dlg = DOpus.Dlg();
I see a similar behaviour with some dialogs who has a lister or a tab as a parent.
I tested a long time ago that the var dlg = DOpus.Dlg();
, script dialog was visible in the taskbar's thumbnails.
I tested according to your tip and the file operation dialog was displayed normally, but the taskbar still displayed the thumbnail of the script dialog.
The problem seems to have occurred again.
