No, doesn´t seem so. I experimented with @nodeselect & "select next", "select prev", but of course this won´t work: @nodeselect refers to a previously used command or function, to reuse the seleted files for the next function, but not to change selection state all by itself.
A command like "select current nodeselect" would be nice for this task. The state would be visible by the normal color highlighting then. Or like in the the image viewer, where selecting/deselecting can be done via "ins" key. Maybe this should be also possible in non-viewer mode?!
I don't know if you've tried it or not but if you have checkbox turned on in details mode, pressing the spacebar toggles the checkbox on/off for highlighted files.
