Filter doesn't work in the recycle bin & Libraries
I discoverd a problem in opus. The filter doesn't work in the recycle bin or in the libararies. At first I thought that it had something to do with virtual folders. So in settings I set opus to handle virtual folders as real but no diffrence? Maybe it's because i run win 7. Since opus can't replace folders like control panel etc that could be the problem
Any ideas?
Special folders are handled by Explorer. DOpus has no way to tell Explorer "don't display files matching this pattern" or anything like that.
See also [File Filter Field vs Recycle Bin)
Oh sorry,,I should have searched the forum a bit more..thanks for reply
