When trying to set following filter (or similar ones), some time values won't stick. Values for seconds, minutes, hours, days work, all greater values, weeks, months, years are falling back to seconds or minutes.
Is this still an issue? Was this about Opus 12 or 13?
We fixed something similar with filters in Opus 13 a few updates ago, but let us know if there's still something that needs looking at.
It isn't fixed yet. Here is what i just tested. First i made the upper filter. Then clicked OK. If i'm not mistaken, the 'older version' of this glitch immediately went back to a minute (or similar), right after this step.
Now i can OK it, and open it again, and the week value i had set would stick. But if i apply it to the main edit window, OK, and open the editor again, i will see the second screenshot.
I found following pattern happening in Opus 13:
Year -> Second
Month -> Hour
Week -> Minute
So setting a week would later be set to a minute, et cetera.
Thanks, I've reproduced it:
- Opus 13, Preferences / Labels / Label Assignments
- Create new Filter Label
datetime match modified within 1 week
- Click OK, click OK again.
- Re-open Preferences and edit it. Changed to
1 minute
We'll get that fixed.
A fix for this will be in the next beta. Thanks again.
