Filter Object and Textual Filter using Evaluator syntax
Greetings,
What would be the correct syntax to use a textual filter with Evaluator in a Filter object? I've tried with:
var filter = DOpus.Create.Filter();
filter.Add('=Match(name,"test","p");');
if (filter.valid())
	DOpus.Output('Valid filter');
else if (filter.lasterror == false)
	DOpus.Output('error:'+filter.lasterror.message);
and although it shows an error, it doesn't tell which one.
Trying to use it with item.MatchFilter directly fails too:
valid is a property, not a method - try if (filter.valid).
Shows the same in both cases:
And what would be the error here? Or Textual Filters with Evaluator are not allowed with a Filter object?
Ok seems to be a glitch.
This is fixed in 13.4.8.
Thanks. And now Textual Filters with Evaluator can be used with a Filter object too :raised_hands:.
