I am among those who want a separate "floating" search dialog... the reason is simple; in that I just do not like having so much of my lister (particularly when I'm in dual horizontal display mode) obscured by the find panel.
Turning the challenge to explain how the old way (or at least different than the current/new way) is better than what we have now around on itself - the only arguments I've ever seen for why the current way is supposedly better than the old is that it contains more useful actual "functionality" than the old tool, and that the old tool had legacy code defects that made it non-optimal to maintain. But those improvements in functionality have nothing to do with the central dislike some users have expressed for having the panel open in-lister. The blissfully ignorant perception of those who know nothing about whatever was code-deficient in the old find tool is most likely that any "functional" improvements in the find panel probably didn't necessitate a non-detachable in-lister panel implementation... but this is just a circular discussion back to the fact that the panel wasn't "new" in v10, that it's been there for YEARS, and was presumably already more agreeably implemented from a code perspective... and wasn't something that was about to be re-written to be "float-able" like the old tool.
For those of you still moaning the loss of the old detached find tool... please make note of the changes in the recent beta's:
With these changes, I think the main 'burden' of using a separate layout from a workflow standpoint has been addressed... namely, that you had to manually CLICK into the name matching field in order to enter your search criteria before executing your search. Well, FIXED - thank you jon!!! Additionally, if you were the type of user who used to output the find results to the Find Window itself, the "Automatically shrink find panel option" is still useful in a separate Find Layout window (though it's probably more for making it more convenient to use the panel in-lister) because now you'll see MORE results in that separate detached lister than you could have seen in the old find tool window - since this option eliminates the find dialog fields from the "window" making more room for viewing more files...
Besides these much appreciated tweaks - I think the challenge from Leo/GPSoft then becomes stating details of what else people feel is important to change and why...
Along those lines - I had sent in very detailed suggestions to GPSoft covering ALL of the ways I think that the use of a dedicated "Find Layout" such as is described throughout this thread... can be enhanced so that it is not only completely functionally equivalent in every way to how the old find tool could be used - but reasons why basing it on the existing "Layout" system makes it better than anything we have or have had. But to Leo's point, there haven't been very many detailed comments here from many users explaining what they want and why it would be better. I can tell you that what I suggested includes a hefty amount of coding work for not a lot of tangible benefit - just to address some otherwise trivial deficiencies that using a separate layout today still has in comparison to the older, slimmer find tool dialog... mainly around how much bulkier a lister layout is (with all the normal toolbars turned on, etc) than just the UI stuff needed for the find fields...
I think, for the majority of users who have expressed dislike for the current in-lister panel method we can pretty safely skip past the fundamental reasons why we don't like having our file displays displaced by the panel, and play ball with what Leo's asking for. Namely - to provide details on what ELSE (since the changes mentioned above have been made) you find disagreeable about using a separate find layout to give you the desired "floating" search dialog you miss. From where we are now, I think the remaining potential "issues" boil down to simply these:
[ul][li]relative visual "bulk" of your normal toolbars when present in a separate find layout - that might look ugly or distracting when used with a minimally sized lister...[/li]
[li]whatever output method you used to use in the old find tools "show results in" drop down[/li][/ul]
Personally, I was never that happy with how the raw FIND command interacted with the old find tool. I recall it not populating the find dialog with options that could be used with the raw command. I stopped trying a long time ago - but now with the old tool having been eliminated - I'd like to see tighter integration with the Find Panel and the raw find command (if not already the case - but implemented in such a way that I could still use the raw command prior to calling up a separate find layout) such that any options used with the command are sure to pre-populate the resulting equivalent fields in the panel. It's not really directly related to replacing the old find tool - but with the changes already made - the only thing I strongly feel is still deficient in the separate Find Layout idea is the bulk of the lister; but is something I think would require a great deal of code change. I'm hopeful that we'll see those changes as the "idea" I've expressed on how to do it would provide other benefit outside of just the "floating search" use-case... but I'd "deal with it" the way it is in favor of more "functional" improvements in how we could use the separate find layout via raw commands - which to me, would make the "new" way unquestionably better than the old way.
ALTERNATIVELY: for those who still won't like the "layout" idea... if it is indeed because the lister is still too bulky compared to the old find tool - what don't you like about using the SMALLEST possible floating search dialog using a RAW command like I posted earlier:
Find NAME {RS|Specify search string...|{clip}} IN {s} RECURSE SHOWRESULTS=tab CLEAR QUIET
The only issue I've had with it - is that there seems to be a strange lag in terms of the operation running and completing vs when results from the operation seem to appear in the lister. On "big" searches - I often see results continue to appear AFTER the operation has seemingly finished (at least the 'abort' message in the display has disappeared, and the main bit of hard drive thrashing seems to have ceased). Haven't submitted an issue for it yet - but will.
</end_another_novella>
