Hi,
I placed a command-field to one of my toolbars.
My intention is, to focus this command-field per Hotkey.
Is this possible?
Thx in advance
x-post: haage-partner.de/forum/viewt ... =25&t=2710
Hi,
Is this possible?
Thx in advance
Go into customize mode (Settings -> Customize), then right-click on the outline representing the command box and select Edit.
A dialog box will appear where you can set a hotkey.
It's look like this (though this screenshot shows a filter field rather than a command field):
Wow, it works!
Thx a lot!
I have to come back on this again.
Is it possible to copy the filename (including the filepath) of the selected file to the commandbox before it gots the focus?
I set the commandbox-hotkey to Alt+C.
Furthermore I set up a hotkey to Alt+C with the following command:
CLI COMMANDSET "{f!}"
This copies the filename to the commandbox, but the focussing does not work any longer
(Using the search-field in command-mode is not a workaround/solution for me, because i have to use the commandbox' history.
I can't see a way to set the string and give it focus from one button (without cheating by using AutoHotkey or AutoIt).
However, you can use {f} etc. directly in the command field, so you could push the key to give it focus and type {f} for the same effect.
What a pity
Thx anyway.
Send GPSoft a request and I'm sure they'll be able to make the CLI command set the focus as well.
Already done
