Which FF is used here? Lister says it uses "Portable Devices" FF but this statement is not true:
I've checked every other FF as well, but could not find anything.
Thanks for the report, this will be fixed in the next update.
Something is still wrong:
And besides the fact "User Default Format" is used instead of "Portable Devices", it also has incorrect columns itself. This is what my real "User Default Format" looks like:
There still seems to be an issue with the folder format shown in the “Info” icon. I created a path format for mtp://MYCAM and it is applied correctly, but this is shown in the info icon:
The format of my path format is clearly applied, so (only) “Portables Devices” seems to be incorrect.
Update: it seems to work correctly when the saved folder format path doesn’t point to mtp://MYCAM/ (i.e., the MTP devices’s root path) but instead to a subfolder like mtp://MYCAM/SD/DCIM.
