Folder Formats Change all Drive formats for D: drive to C: Drive
Version 12.20x64
I have given up on the 2 drive system C: having just OS and D: having Data. I have about 20 folder formats pointing to D: drives and would love to have a quick way to have them point to the C: drive with the identical directory format that existed in D:. i.e. D:\Users\DoRun\Downloads is now C:\Users\DoRun\Downloads.
Many thanks in advance.
You could edit the config files directly:
/dopusdata\Formats\folders.off
They are just text files so you could do a find and replace (D:\ to C:\).
Use at your own risk though - it's not generally recommended that you directly edit these files.
I would make sure Directory Opus is not running (at all) before saving the modified file.
Also, you should make a backup of your config prior to any editing.
Thanks very much !!!! That did the trick.
David
Thanks I figured it was a file somewhere just couldn't find the location. Just used Notepad++ and changed all the locations, restarted Directory Opus and everything worked perfectly.
Thanks,
David
