Folder structur left side
Hello. The configuration of the folder structure since several updates does not match the way it is confugured in preferences. Opening/closing active/notactive trees doesn't do as described and radio-checked, and corresponding clicks at the tree do not trigger the correct folder-path in the main-windows and vice versa. Could you please fix those issues? It would be great to see opus work as awaited here.
Can you show some example screenshots and describe where you're clicking and what happens?
Screenshots of the whole window are best, so we can see how things are configured.
