Folders not visible in Document and Setting
I needed to delete a file in Outlook Express and went to Documents and Setting, my users area and local settings but the local settingx folder was not visible.
I went back to windows explorer (I hate that program) and no problem seeing this folder.
What needs to be changed in DO to see the missing folders in documents and setting.
Thanks.
Using v9.1
Your global settings or folder format hides folders with Hidden and/or System attributes.
See screenshot
And how is set up your folder format user for Documents And Settigns display?
(Yeah, I know what this option says, but I have it CHECKED and still see all the folders you miss).
Is it just the folder tree or the file display as well?
I saw that option and its UNCHECKED.
Any more suggestions?
Thanks.
Under Listers / Folder Tree, make sure 'Hidden folders' is enabled.
That did it.
Thanks and I really like DO!
