I just updated to version 12.13 and the installer defaults to a 32 bit installtion and then crashs on Windowx 10. Version 12.12 installed as a 64 bit version. How do I force the 64 bit upgrade.
You must have one of the compatibility mode options turned on for the installer exe. They should all be off.
