Force scrollbar to top when clicking on modified column?
Currently, if a file is selected, and you click on the modified column to change the sort order, the selected item determines the scroll bar position.
I'd like to be able to optionally or by default, change the behavior so that the scroll bar is always located at the very top.
So, sorting by the oldest, puts the scroll bar at the top with the oldest files showing, and reversing the sort order puts the scroll bar at the top with the newest files.
Is this possible - or a feature request?
See: [List sorted by column - possible to have scroll bar move to)
Leo - thanks!
One thing I really like about Opus - is that you can get an amazingly quick answer, and 99% of the time it's a solution.
