Forum code blocks have changed
What are the new rules for code blocks ?
for instance code with empty lines gets divide into sections ?
if (operation == "sort")return Age(createddate);
date_now		= Now();when_created 	= createddate;
mins	= Age(when_created, "n");hours	= Age(when_created, "h");  // buggyhours 	= Abs(mins / 60);days	= Age(when_created, "d");weeks 	= Age(when_created, "w");months 	= Age(when_created, "m");years 	= Age(when_created, "yyyy");
It looks like you entered it like that deliberately?
If you type it as one block empty lines are no problem.
It was copied & pasted as one chunk. Then selected and then clicked preformatted text.
Discourse has been updated recently - for instance entering posts is different - no previews anymore and shrinking images is different.
That doesn't happen here, FWIW.
Pasted and selected:
Then if I click Preformatted Text, it's turned into a single code block:
No preview here either on Chrome 140.0.7339.81 (Official Build) (64-bit)
Edit: No preview and code block does not format
Same Chrome version I am using, so it's probably a browser extension breaking things.
I’m using latest Edge build.
Using
[code]
code here
empty line and more code
[/code]
and
code here
does not appear to work either. As per
It was closed recently, I opened it manually.
Ah yes, if that toggle is in "rich edit" mode instead of "Markdown", you won’t get a preview and can’t use markdown, and preformatted text doesn’t work properly.
I have no idea why Discourse even added that option, and would remove it if there was a way. I have no idea why they do a lot of things lately.
That has been there for a few months, FWIW, so it's not a recent change.
I've changed the default to Markdown, which should help at least.
That was my issue as well. Thanks for identifying and resolving!
:slight_smile: :+1:
