I usually try to fit what I'm looking for into larger context that'll benefit the majority... but I honestly don't know how many other ppl will really need what I'm asking for here.
My use case is for various recovery environment scenarios and the fact that I have a variety of USB flash keys with different pre-boot tools for different situations, most of them managed through Opus (toolbars, popup menus, etc) since it's easy to 'find' stuff in Opus using all the nifties (volume label references, aliases, etc). Constantly updating apps individually on these keys is a pain, so I've taken to storing them inside the WinPE images I'm using to host my recovery environments. They load from my SSD's in most cases so they're zippy and fast too... yay! But for my bootable keys, I still have to copy over a rather large WinPE image file, but once I've updated the image with any tool updates, it's easy to update multiple keys with this single new file. But to create a WinPE image with correct Opus licensing for a given key, I have to make multiple copies of my ~golden boot.wim file (~1GB), mount them separately one at a time, update the appropriate dopus.cert file for the key I'm copying the WinPE to, and then commit and copy it to the USB.
It would be very handy to be able to do something within the USB Export feature that could allow me to ADD dongle support for a USB key to an existing certificate... such that I could end up with a single dopus.cert that could be used with multiple keys. Either that, or some mechanism by which I could copy multiple separate dopus.cert files into a folder that Opus could look for on startup if there's no dopus.cert file in the normal location or something.
Again, not sure how many other ppl would have any interest in this, and hope it's not something you might be concerned could further encourage piracy in some way... etc.
Thanks for listening.
