Skeeve
March 10, 2017, 6:27pm
1
When reviewing multiple sound files with the internal dopus player, dopus freezes after a while.
I have to say I do this very fast. I switch with the keyboard cursor keys between files and I've defined a shortcut to open the audio player. When I do an intense review session, dopus usually freezes after 2-3 minutes. But it's not 100% reproducible.
Is there anything I can do after the freeze happened, so you guys can track it down? I.e. starting VS, attaching to the dopus thread, break and send you the call stack? Would that be of any help?
Kind regards,
Skeeve
Leo
March 10, 2017, 6:47pm
2
The problem could be in Opus or it could be in the system codecs involved.
If you want to send us a dump, we can probably use it to see where things are going wrong. Here's how:
While it's happening, please go to Task Manager , then the Details tab, right-click dopus.exe and select Create Dump File .
Do that 4 or 5 times, and it should create something like:
C:\Users\<username>\AppData\Local\Temp\dopus.DMP
C:\Users\<username>\AppData\Local\Temp\dopus (2).DMP
C:\Users\<username>\AppData\Local\Temp\dopus (3).DMP
C:\Users\<username>\AppData\Local\Temp\dopus (4).DMP
C:\Users\<username>\AppData\Local\Temp\dopus (5).DMP
The files will be large, but compress well.
If sending more than one file, using the 7z format instead of zip will give a much reduced size. You can do this via the Archive Files button in Opus.
Please zip or 7z the files and email them to crashdumps@gpsoft.com.au
Skeeve
March 15, 2017, 8:01pm
3
This happened now again during intense tests.
I've created dumps by following your guide and sent a mail to the provided address.
Thanks,
Kind regards,
Skeeve
Skeeve
March 19, 2017, 4:51pm
4
Did you get the mail with the dumps?
Kind regards,
Skeeve
Leo
March 19, 2017, 5:52pm
5
Is it possible to check if disabling/uninstalling Bullguard has any effect?
There's nothing conclusive in the dumps, but BgAgent.dll does seem to have been injected into the callstack somehow in two of the threads that look involved, which makes me wonder if it is triggering some kind of problem. It's not a DLL I would expect to be in either code-path, but it looks like some kind of security tool so it may patch/hook various APIs and perhaps that is going wrong in some way.
Skeeve
March 20, 2017, 7:09pm
6
Hi Leo,
Many thanks for your analyse.
Good point, the security software (Bullguard) definitely seems to be involved in this. I've added an exception to bullguard, that excludes the dopus process from all realtime checks and I couldn't reproduce the issue any longer so far. (It usually happened every 2-3 minutes in extensive tests)
It even seems to have effects to other issues I've had. If you're interested I keep you up to date, but still want test this for some time.
Thanks again,
Kind regards,
Skeeve
orbik
October 19, 2021, 5:32pm
7
I had this problem in the past, and still happens after upgrade to version 12, but only on my older PC running Windows 7. It has multiple audio devices, WinMM sees 11 stereo outs in total, in case it matters. The call stacks looked like it's related to unloading a sound driver.
The most reliable way to reproduce
Open a folder with short (~0.5s) wav files
Internal sound player enabled, set to auto-close on finish
Play many sounds in quick succession, about 5 per second
DOpus usually freezes within ~10 seconds, but it's unpredictable.
Some of the sound player windows also fail to close on finish, even no freezing has occurred.
I'm not really comfortable with sending a full minidump - contains all kinds of personal info, file names etc. But I copied the thread info if it helps.
Threads and call stacks
Main Thread Main Thread dopus.exe!000000013fbf6550
> ntdll.dll!ZwWaitForSingleObject()
KERNELBASE.dll!WaitForSingleObjectEx()
dopus.exe!000000013fbf6550()
dopus.exe!000000013f87f795()
dopus.exe!000000013f87f3b4()
dopus.exe!000000013fb9744e()
dopus.exe!000000013fb9da84()
user32.dll!UserCallWinProcCheckWow()
user32.dll!DispatchMessageWorker()
dopus.exe!000000013fba93cb()
dopus.exe!000000013fba34d0()
dopus.exe!000000013fba292b()
dopus.exe!000000014025e182()
kernel32.dll!BaseThreadInitThunk()
ntdll.dll!RtlUserThreadStart()
RPC Thread RPC Callback Thread ole32.dll!000007fefe2dd828
> ntdll.dll!ZwDelayExecution()
KERNELBASE.dll!SleepEx()
ole32.dll!CROIDTable::WorkerThreadLoop(void * param) Line 1345
ole32.dll!CRpcThread::WorkerLoop() Line 257
ole32.dll!CRpcThreadCache::RpcWorkerThreadEntry(void * param) Line 63
Worker Thread crypt32.dll thread crypt32.dll!000007fefd249bb0
ntdll.dll!RtlpWaitOnCriticalSection()
ntdll.dll!RtlEnterCriticalSection()
ntdll.dll!LdrUnloadDll()
KERNELBASE.dll!FreeLibrary()
crypt32.dll!FreeDllWaitForCallback(void *,unsigned char)
crypt32.dll!ILS_WaitForThreadProc(void *)
Worker Thread dopus.exe thread dopus.exe!000000013f3f9cc5
dopus.exe!000000013f3f9cc5()
dopus.exe!000000013f3f9c09()
dopus.exe!0000000140264b74()
Worker Thread dopuslib.dll thread dopus.exe!000000013f458339
> user32.dll!NtUserGetMessage()
user32.dll!GetMessageW()
dopus.exe!000000013f458339()
dopuslib.dll!000007fee1f4a124()
dopuslib.dll!000007fee200b02c()
Worker Thread dopuslib.dll thread dopus.exe!000000013f7168fd
dopus.exe!000000013f7168fd()
Worker Thread dopuslib.dll thread dopus.exe!000000013f7b6b6f
> user32.dll!ZwUserMessageCall()
user32.dll!SendMessageWorker()
user32.dll!SendMessageW()
dopus.exe!000000013f7b6b6f()
dopus.exe!000000013f7b6627()
dopus.exe!000000013f7b4626()
dopus.exe!000000013f768be5()
dopus.exe!000000013fdc7157()
Worker Thread dopuslib.dll thread dopus.exe!000000013f7d9627
dopus.exe!000000013f7d9627()
dopus.exe!000000013f7d92c9()
Worker Thread dopuslib.dll thread dopus.exe!000000013f81e254
dopus.exe!000000013f81e254()
Worker Thread dopuslib.dll thread dopus.exe!000000013f9a276e
dopus.exe!000000013f9a276e()
Worker Thread dopuslib.dll thread dopus.exe!000000013f9ace7d
> user32.dll!ZwUserWaitMessage()
dopus.exe!000000013f9ace7d()
dopus.exe!000000013f9ac95a()
dopus.exe!000000013f9ac7d1()
Worker Thread dopuslib.dll thread dopus.exe!000000013f9e5001
dopus.exe!000000013f9e5001()
Worker Thread dopuslib.dll thread dopus.exe!000000013fbd9e84
dopus.exe!000000013fbd9e84()
kernel32.dll!UnhandledExceptionFilter()
ntdll.dll!string "Enabling heap debug options\n"()
ntdll.dll!__C_specific_handler()
ntdll.dll!RtlpExecuteHandlerForException()
ntdll.dll!RtlDispatchException()
ntdll.dll!KiUserExceptionDispatch()
dopuslib.dll!000007fee201fb12()
dopuslib.dll!000007fee20200da()
dopuslib.dll!000007fee201fefa()
ntdll.dll!RtlProcessFlsData()
ntdll.dll!LdrShutdownThread()
ntdll.dll!RtlExitUserThread()
KERNELBASE.dll!FreeLibraryAndExitThread()
kernel32.dll!FreeLibraryAndExitThreadStub()
dopuslib.dll!000007fee200b1bf()
dopuslib.dll!000007fee200b469()
dopuslib.dll!000007fee200b033()
Worker Thread dopuslib.dll thread dopus.exe!000000013fbee5db
dopus.exe!000000013fbee5db()
dopus.exe!000000013fbee4e9()
Worker Thread dopuslib.dll thread dopus.exe!000000013fc410f4
> ntdll.dll!NtWaitForMultipleObjects()
KERNELBASE.dll!WaitForMultipleObjectsEx()
kernel32.dll!WaitForMultipleObjectsExImplementation()
user32.dll!RealMsgWaitForMultipleObjectsEx()
user32.dll!MsgWaitForMultipleObjectsEx()
user32.dll!MsgWaitForMultipleObjects()
dopus.exe!000000013fc410f4()
dopus.exe!000000013fc40717()
Worker Thread dopuslib.dll thread dopus.exe!000000013fd0a57d
dopus.exe!000000013fd0a57d()
Worker Thread dopuslib.dll thread dopus.exe!000000013fd10d79
dopus.exe!000000013fd10d79()
Worker Thread dopuslib.dll thread dopus.exe!000000013fd111e7
dopus.exe!000000013fd111e7()
Worker Thread dopuslib.dll thread dopus.exe!000000013fd129f4
dopus.exe!000000013fd129f4()
Worker Thread dopuslib.dll thread dopus.exe!000000013fd17d8e
dopus.exe!000000013fd17d8e()
Worker Thread dopuslib.dll thread dopus.exe!000000013fd1d70a
dopus.exe!000000013fd1d70a()
Worker Thread dopuslib.dll thread dopus.exe!000000013fd486b5
dopus.exe!000000013fd486b5()
Worker Thread dopuslib.dll thread dopus.exe!000000013fddb266
dopus.exe!000000013fddb266()
Worker Thread dopuslib.dll thread dopus.exe!000000013fe0740b
dopus.exe!000000013fe0740b()
dopus.exe!000000013fe072a1()
Worker Thread dopuslib.dll thread dopus.exe!000000013fe3838d
dopus.exe!000000013fe3838d()
dopus.exe!000000013fe381ec()
Worker Thread dopuslib.dll thread dopus.exe!000000013fe4fd9b
dopus.exe!000000013fe4fd9b()
dopus.exe!000000013fe4ebe4()
Worker Thread dopuslib.dll thread dopuslib.dll!000007fee1f2db28
dopuslib.dll!000007fee1f2db28()
Worker Thread dopus.exe thread dopuslib.dll!000007fee201fa34
dopuslib.dll!000007fee201fa34()
dopuslib.dll!000007fee201fec6()
dopuslib.dll!000007fee2020581()
dopuslib.dll!000007fee200e401()
dopuslib.dll!000007fee1fac81a()
dopuslib.dll!000007fee1facb49()
dopuslib.dll!000007fee1facd7c()
ntdll.dll!LdrpInitializeThread()
ntdll.dll!_LdrpInitialize()
ntdll.dll!LdrInitializeThunk()
Worker Thread winmm.dll thread dopuslib.dll!000007fee201fafc
dopuslib.dll!000007fee201fafc()
Worker Thread DropboxExt64.49.0.dll thread DropboxExt64.49.0.dll!000007feea9d964b
> ntdll.dll!ZwFsControlFile()
KERNELBASE.dll!ConnectNamedPipe()
DropboxExt64.49.0.dll!000007feea9d964b()
Worker Thread GdiPlus.dll thread GdiPlus.dll!000007fef5202d8c
GdiPlus.dll!BackgroundThreadProc(void *)
GdiPlus.dll!DllRefCountSafeThreadThunk(void *)
Worker Thread dopuslib.dll thread mciwave.dll!000007feecb45100
mciwave.dll!mciDriverEntry()
mciwave.dll!DriverProc()
winmm.dll!InternalBroadcastDriverMessage()
winmm.dll!mciSendSingleCommand()
winmm.dll!mciSendCommandInternal()
winmm.dll!mciSendCommandW()
msvfw32.dll!MCIWndStatus()
msvfw32.dll!MCIWndProc()
msvfw32.dll!MCIWndiTimerStuff()
user32.dll!IsDialogMessageW()
dopus.exe!000000013fc17741()
dopus.exe!000000013fc17338()
dopus.exe!000000013f91a47a()
Worker Thread winmm.dll thread mciwave.dll!000007feecb45bcc
mciwave.dll!TaskBlock()
mciwave.dll!mwTask()
winmm.dll!mmStartTask()
Worker Thread MMDevAPI.dll thread MMDevAPI.dll!000007fefb9b35be
MMDevAPI.dll!CDeviceEnumerator::PnpNotificationThread(void)
Worker Thread dopuslib.dll thread msctf.dll!000007fefe7eacd2
ntdll.dll!LdrLockLoaderLock()
KERNELBASE.dll!GetModuleFileNameW()
user32.dll!SetWinEventHook()
msctf.dll!CThreadInputMgr::SetFocusEventHook(void)
msctf.dll!CThreadInputMgr::Resume(void)
msctf.dll!CThreadInputMgr::ActivateEx_P(unsigned long *,unsigned long)
msctf.dll!CicBridge::ActivateIMMX(class TLS *,struct ITfThreadMgr_P *,unsigned long,unsigned long)
msctf.dll!CtfImeCreateThreadMgr()
imm32.dll!CtfImmTIMActivate()
imm32.dll!InternalImmLockIMC()
imm32.dll!ImmSetActiveContext()
user32.dll!FocusSetIMCContext()
user32.dll!ImeSystemHandler()
user32.dll!ImeWndProcWorker()
user32.dll!__fnDWORD()
ntdll.dll!KiUserCallbackDispatcherContinue()
user32.dll!ZwUserSetWindowPos()
dopus.exe!000000013f91a708()
dopus.exe!000000013f91a5d6()
user32.dll!UserCallDlgProcCheckWow()
user32.dll!DefDlgProcWorker()
user32.dll!InternalCreateDialog()
user32.dll!CreateDialogIndirectParamAorW()
user32.dll!CreateDialogIndirectParamW()
dopus.exe!000000013fc195a5()
dopus.exe!000000013f91a3d1()
Worker Thread msiltcfg.dll thread msiltcfg.dll!000007feeabe21d6
kernel32.dll!WaitForMultipleObjects()
msiltcfg.dll!WorkerThread(void *)
Worker Thread ntdll.dll thread ntdll.dll!00000000775f9e3a
ntdll.dll!TppWaiterpThread()
Worker Thread ntdll.dll thread ntdll.dll!00000000775fb0ca
> ntdll.dll!ZwTraceControl()
ntdll.dll!EtwpNotificationThread()
Worker Thread ntdll.dll thread ntdll.dll!00000000775fb18a
> ntdll.dll!ZwWaitForWorkViaWorkerFactory()
ntdll.dll!TppWorkerThread()
Worker Thread shlwapi.dll thread shell32.dll!000007fefd5468e8
shell32.dll!MessagePumpThreadProc(void *)
shlwapi.dll!WrapperThreadProc(void *)
Worker Thread winmm.dll thread wdmaud.drv!000007fee6e72756
wdmaud.drv!CWorker::`scalar deleting destructor'(unsigned int)
wdmaud.drv!CWaveHandle::~CWaveHandle(void)
wdmaud.drv!CWxd::Close(class CWaveHandle *)
wdmaud.drv!wodMessage(unsigned long,unsigned long,unsigned __int64,unsigned __int64,unsigned __int64)
winmm.dll!waveOutClose()
msacm32.drv!mapWaveClose()
msacm32.drv!wodMessage()
Worker Thread wdmaud.drv thread wdmaud.drv!000007fee6e72949
ntdll.dll!LdrGetDllHandleEx()
ntdll.dll!LdrGetDllHandle()
KERNELBASE.dll!GetModuleHandleForUnicodeString()
KERNELBASE.dll!BasepGetModuleHandleExW()
KERNELBASE.dll!GetModuleHandleW()
ole32.dll!wCoUninitialize(COleTls & Tls, int fHostThread) Line 2832
ole32.dll!CoUninitialize() Line 2629
wdmaud.drv!CWorker::_StaticThreadProc(void *)
Worker Thread dopuslib.dll thread winmm.dll!000007fef03f66cf
winmm.dll!InternalFreeDriver()
winmm.dll!DrvClose()
winmm.dll!mciCloseDevice()
msvfw32.dll!MCIWndiClose()
user32.dll!DispatchClientMessage()
user32.dll!ZwUserDestroyWindow()
dopus.exe!000000013f91a8a8()
dopus.exe!000000013f91a606()
user32.dll!DefDlgProcW()
user32.dll!CallWindowProcAorW()
user32.dll!CallWindowProcW()
comctl32.dll!CallOriginalWndProc()
comctl32.dll!CallNextSubclassProc()
comctl32.dll!DefSubclassProc()
dopus.exe!000000013f40a03c()
comctl32.dll!MasterSubclassProc()
dopus.exe!000000013f91ab6a()
dopus.exe!000000013f91b1f2()
dopus.exe!000000013f91a671()
Worker Thread dopuslib.dll thread winmm.dll!000007fef03f675f
Leo
October 19, 2021, 5:40pm
8
My guess is it's an audio driver issue.
The stacks show it's hanging within the Windows code while trying to close a driver. (The word "driver" in the logged function names may not literally mean the hardware driver there, but is probably still something that ultimately depends on the hardware driver in either case.)
That would also explain why it only goes wrong on one machine, assuming the same files were tested on the other machine.
I would try updating the driver from the motherboard / sound card OEM, or getting the driver from the sound chipset manufacturer, depending on the type of sound hardware. (Sometimes you have both options, and one may work better than the other.) The sound (and video) drivers that come with Windows and Windows Update are often not great.
orbik
October 19, 2021, 5:49pm
9
Changing the driver isn't a feasible solution for me. I'm using kX project (3rd party FOSS driver) with an Audigy 2 card. It works perfectly with all other applications - good for music production, even allows programmable DSP, unlike Creative's old crappy driver.
There's one thread apparently stuck in some exception handler. Does Opus perhaps log exceptions somewhere to give a better clue?
orbik
October 19, 2021, 6:02pm
10
I tested changing the default sound device to an external FireWire box, completely different driver. Same thing happens with Opus. Maybe it's something that only occurs on older Windows versions, but there's this creeping suspicion that a an obscure bug is still hiding, waiting to resurface
Leo
October 19, 2021, 6:45pm
11
This thread is almost 5 years old so "old Windows versions" today would have been current back then, and the code involved was written for even older versions and used by people on them for a long time without many similar reports.
The original thread we're on the end of turned out to be a problem caused by security software, and only seen by one person.
That's what process snapshots are for. We can look at them if you send them.
orbik
October 20, 2021, 4:12pm
12
I dug a bit more into this. The problem occurs on Win10 too, but with a proper crash notification instead of deadlock, and it takes far longer to crash than in Win7.
If you use gflags, the Windows debugging tool, to "Enable page heap" for dopus.exe, and play any wav file with auto-close on finish, there is always an access violation in dopus.playsndthread
in MSVFW32!MCIWndiTimerStuff
. It tries to update the trackbar after the window is already destroyed. It only happens with auto-close, and if user didn't stop and restart playback,
With page heap validation off in gflags, that thread seems to die silently, but afterwards there's something wrong with heap blocks, e.g.
HEAP[dopus.exe]: HEAP: Free Heap block 4f7d420 modified at 4f7d4b8 after it was freed
These can be reproduced 100% on both systems.
After lots of repetition on Win10 you get an access violation crash from what looks like decrementing an atomic counter. Win7 looks the same, but the exception handler causes a deadlock between 3 threads:
Exception handler, waiting for thread 2.
Waiting for LdrpLoaderLock
in order to start
Holds LdrpLoaderLock
, waits for a CritSect that (1) acquired just before the access violation.
The exact instruction that causes access violation varies between tries, but it's always been of the form:
lock xadd dword ptr [rcx],eax
, closely after calling EnterCriticalSection
Leo
October 20, 2021, 4:57pm
13
Thanks! I will take a look to see if there's something we can do on our side to avoid that happening.
Leo
October 20, 2021, 8:08pm
14
We've fixed that for the next beta. Thanks again!
With PageHeap turned on I was able to reproduce the problem every time. Many thanks for that piece of info, as it made things easy to track down. With the new code, it no longer happens for me even with PageHeap on but, of course, if you still see a problem once the new beta is out, please let us know.
It turned out to be caused by closing the (invisible) Windows MCI window while handling the "finished playing" message it sends us. It must not check for its window being destroyed inside a notification (easy to overlook; we've had issues like that as well). Postponing the MCI window close until after returning from the notification fixes things.
