French's Translation
DO 10.1.0.0 some trings is not translated, sample: From Search: Remove from collection, Open containing folder...
Those two context-menu items seem to be stuck in whichever language Opus was initially installed with.
We'll get that fixed in a future update.
If you want to rename them manually now, here's how:
[ul][li]Go to Settings -> File Types... (Paramètres -> Types de fichier...)
[/li]
[li]Double-click Collection Item (Fichiers des Collections) near the top.
[/li]
[li]You'll see the two items in the list that opens. The French labels are &Retirer de la Collection and Ouvrir le dossier &contenant (the & characters define the shortcut keys).[/li][/ul]
Hi Leo
there is an grammar error that exists since the beginning.
When you permanently delete a file (Shift+Suprr), the error message is:
"Suppression de fichier - Directory Opus
X fichiers (Y Go au total) sera(ont) supprimé(s).
Voulez vous vraiment supprimés ces fichiers ?"
It should be:
Voulez vous vraiment supprimer ces fichiers ?"
TIA for the correction.
Thanks. We'll fix this in the next update.
