Ryze
June 11, 2018, 7:47pm
1
Example case:
var b = DOpus.Create.Blob();
var string = 'Lets try this string';
b.copyFrom(string);
DOpus.output(new ActiveXObject("WScript.Shell").Exec('perl -mDigest::SHA1 -e "print Digest::SHA1::sha1_hex(\'' + string + '\')').StdOut.readAll()); // correct hash
DOpus.output(DOpus.FSUtil().Hash(b, 'sha1')); // incorrect
Output:
516b09f4441bc72dda70cd88c57a7a5945423176
99d5a7c2b21ba2a3440f4f95db181e5cde4e27ac
(I can confirm that perl calculates the correct hash -- other sources can as well)
Leo
June 11, 2018, 7:50pm
2
You're probably hashing different representations of the string, e.g. UTF-16 vs UTF-8.
StringTools provides ways to convert between encodings.
Also, from the 12.9.1 release notes :
The Blob.CopyFrom method now lets you initialise a Blob from a string. By default the Blob will be set to the Unicode form of the string; if you pass "utf8" as the second parameter it will initialise the Blob with the utf8-encoded form of the string .
Ryze
June 11, 2018, 7:53pm
3
Yep Leo, you are right.
b.copyFrom(string,'utf8');
DOpus.output(DOpus.FSUtil().Hash(b, 'sha1')); // correct now
