Hello. If i pause FTP copying (from phone to desktop using "Wi-Fi FTP server" app connection) i can't resume it (if connection was lost then appeared again on the same port and IP). it just stays and do nothing...
and by the way, double click on FTP's image with this command doesn't work at ALL! (Perhaps because of LISTERLINK??)
Is there are any error information in the FTP log? (Should be available from the FTP menu, if using default toolbars.)
I've made a note to look at Show LISTERLINK on FTP with double-click. Seems to be downloading the file rather than passing the URL straight to the viewer. It does work when run via a toolbar button, if that helps.
tried new copy... with video
first error - on turning of server with app. restarting server doesn't start copying and even Opus can't read the same folder (only going up to root helps)
second "error" (silent) - when i turn off Wi-Fi on phone. reconnecting to Wi-Fi and restarting server do nothing with copying. as in first case - Opus can't find an old folder except of going to root all-activity.txt (9.3 KB)
Looks like the server side is closing the connection. May mean it has a very short timeout.
(Pausing just stops processing new data, so with something like FTP it will timeout after a while. Timing out or disconnecting instantly is quite strange through, and doesn't happen with the sites/servers I've tested with so far.)
