Hello everyone
I think I experienced a bug - but I cannot reproduce it without probably doing a clean install of Windows etc.
I am using Dopus 13.4.
It is set to GERMAN
Issue: When I access an FTP server with DANISH files (files have danish special letters) the special letters are displayed as a box.
Now - the ususal approach here is to fiddle with the encoding settings. I own the FTP server so I had a chance to both work with the server settings and the settings in Dopus.
Nothing worked.
I did set UTF-8 to "forced" on the server. Tried to disable ASCII and other random stuff.
At the same time all worked well in FileZilla. So I might have been a DOPUS issue.
And then I got an idea:
- I changed the DOPUS language to Danish and it solved the problem.
- And then I switched Dopus back to German and it still handles all the danish special characters.
So it seems like Dopus is not loading the danish special characters when I install Dopus in German?
Anyway - thanks for a great program
