I cannot copy marked file. KSIPWWW~2.
On server side its a 108KB file .
When i trying to copy to my comp. i get only 64 KB.
I tried:
copy other files - as you see, they all copied without problems.
get this file via ftp from command-line in other server = OK
change filename to 232323 = still only 64 KB.
swich Active/Passive modes = without success.
I enabled DEBUG mode on FTP:
227 Entering Passive Mode (xxxxxxxx,134,209)
150 Opening BINARY mode data connection for KSIPWWW~OC4J_KSIPWWW~KSIPWWW~2.log (111548 bytes).
65536 bytes received in 0.93 seconds (687.512 Kbytes/sec)
226 Transfer complete.
Opening Connection xxxxxxxxxx:21
220 xxxxxxxx FTP server (Revision 1.1 Version wuftpd-2.6.1(PHNE_36065) Mon Apr 14 06:16:29 GMT 2008) ready.
331 Password required for root.
230 User root logged in.
215 UNIX Type: L8
500 'FEAT': command not understood.
200 Type set to I.
257 "/root" is current directory.
250 CWD command successful.
257 "/u01/oracle/product/AS1013/opmn/logs" is current directory.
200 Type set to A.
200 PORT command successful.
150 Opening ASCII mode data connection for /usr/bin/ls.
1620 bytes received in 0.27 seconds (58.608 Kbytes/sec)
227 Entering Passive Mode (xxxxxxxxxxxx,79,36)
65536 bytes received in 0.110 seconds (581.56 Kbytes/sec)
1686 bytes received in 0.27 seconds (60.560 Kbytes/sec)
227 Entering Passive Mode (xxxxxxxxxxxxxx,237,92)
150 Opening BINARY mode data connection for 232323 (111548 bytes).
65536 bytes received in 0.109 seconds (586.936 Kbytes/sec)
227 Entering Passive Mode (xxxxxxxxxxxx,31,232)
65536 bytes received in 0.94 seconds (680.680 Kbytes/sec)
Connection closed
What wrong is with this file?
Opus: 9.5.3.0.3728.x86
[ul][li]Does this happen for other files on that server, or just that one? Is it only files in that logs directory or every file you try?
[/li]
[li]I think 64KB is the default buffer size used by Opus for FTP transfers, so there may be a connection there.
See if changing the buffer size either fixes the problem or results in the new size being the amount that is transferred. That may shed light on what's happening.
The buffer size can be set under Settings - Preferences - Miscellaneous - Advanced: ftp_copy_buffer_size. The size is in bytes and 65536 (64KB) is the maximum (anything higher will be ignored), so try a lower value like 32768 (32KB).[/li][/ul]
Before i changed it, i have a 0 (ZERO) here. I never changed it before.
Receive this file. i copied in on OS into new file with other name (original also exists)
Opening Connection xxxxxxxx:21
215 UNIX Type: L8
200 Type set to I.
200 Type set to A.
1694 bytes received in 0.27 seconds (60.560 Kbytes/sec)
200 Type set to I.
150 Opening BINARY mode data connection for ML_nie_kasowac (111548 bytes).
ftp_copy_buffer_size = 32 kb. Restarted Dopus.
215 UNIX Type: L8
200 Type set to I.
200 Type set to A.
200 Type set to I.
Other file? Log with receive a 445 KB file (opmn.log). File has been successfuly copied!
Look at "32768 bytes received in 0.110 seconds"
215 UNIX Type: L8
200 Type set to I.
200 Type set to A.
200 Type set to I.
150 Opening BINARY mode data connection for opmn.log (456457 bytes).
32768 bytes received in 0.110 seconds (290.40 Kbytes/sec)
Did you compare the partially copied files with the original files (i.e. using beyond compare). Maybe it's some weird character within the file that prevents DOpus from copying.
Yeah, 40, 500, 9999
1 = ok. But... file copy is immediate (1 sec) - what this option doing?
OK, Leo, i performed more tests:
If we come into FTP -> Edit Address Book, there are general settings.
If i enter here Limit Download Speed = 50, my file is cut on FFFF (65535 = 64 KB).
If i turn this off and go to specified server entry, turn off here "use defaults" and enter here 50 = BAD
If i turn on "use defaults"... (no speed limits in general, no speed limits on entry) = OK.
Problem is located with this option.
PS. Why when i set this limit to "1", i got file in one second?
Trying to copy file 200 MB.... slowly... 32 kb copied... wait... wait... 64 kb copied... - this take some seconds.... i cancel transfer, working ok.
Trying to copy opmn.log , filesize 445 KB with same setting, in same ftp session. Copied in 1 second.
--------------- OK, and here is a problem:
filesize = 531.897 bytes = copied in one second
filesize = 538.260 bytes = speed limit is working.
problem is located between filesize 531.897 and 538.260 bytes.
I don't have now time to split them for smaller parts to find this border where it's located.
Leo, if you want to do more tests, contact with me via PM.
