Get an Alias for a Path, if assigned
Evaluator provides the Resolve function to determine the path for an alias. I'm interested in going the opposite way, specifically with Evaluator if at all possible.
USE CASE: I have a button whose label is set to a truncated version of the active tab path.
I would like to include alias in the tooltip, if one exists for the active tab path.
Any ideas?
Tricky. I am afraid the Evaluator can't enumerate aliases. A function like Aliasify or a flag for Resolve() would definitely be a useful :+1:
I agree with this feature request!
We've added that for the next beta.
Trying to use Resolve with the "a" modifier ion paths that have an alias. I am not getting anywhere.
I've tried:
Output(Resolve("{sourcepath}",a);
and...
Output(Resolve("{sourcepath}","a");
I get this popup:
What am I missing?
I haven't installed the new beta yet as of tonight.
But I think you had it right in the first post.
Output( source ) ; works from a button as does Output( Resolve( source ));
I am testing it via a button and getting the result I posted earlier.
If you want to run raw evaluator code from a button you need to change the type of the function to Evaluator Function.
Use source rather than {sourcepath} in the evaluator.
 12/17/2025 9:14 PM Evaluator:  Error at line 1, position 23 [Evaluator Function: New Button]
Unknown value (6): a
Output(Resolve(source,a);
 12/17/2025 9:15 PM Evaluator:  Error at line 1, position 25 [Evaluator Function: New Button]
Output(Resolve({source},a);
 12/17/2025 9:16 PM Evaluator:  Error at line 1, position 27 [Evaluator Function: New Button]
Output(Resolve("{source}",a);
 12/17/2025 9:16 PM Evaluator:  Error at line 1, position 25 [Evaluator Function: New Button]
Output(Resolve("source",a);
 12/17/2025 9:19 PM Evaluator:  Error [Evaluator Function: New Button]
Scope mismatch (2)
Output(Resolve(source,"a");
 12/17/2025 9:20 PM Evaluator:  Error [Evaluator Function: New Button]
Scope mismatch (2)
Output(Resolve("source","a");
Scope mismatch (2)
Output(Resolve("{source}","a");
 12/17/2025 9:21 PM Evaluator:  Error [Evaluator Function: New Button]
Scope mismatch (2)
Output(Resolve({source},"a");
It looks like you are missing the closing parenthesis for Output() in all of these.
I think that's what Scope mismatch is .
Dang it. Thanks for pointing that out. I will validate tomorrow.
I think you need to study the variable types of the evaluator. The parameter for Resolve() is a 'path' type path and an optional 'string' type flags.
source is already of type 'path', no quotes needed.
Output(TypeOf(source))
// output:path
Resolve(
     path:path,
     [string:flags]
→ path
Thanks to everyone for the assistance. Despite reviewing the documentation and searching these forums for examples, I missed at least four things:
  1. used {sourcepath} instead of source
  2. used a instead of "a"
  3. missed a space after source,
  4. missed the closed paren ) for Output
In other words, I got almost nothing right.
Having corrected all that...
... I am getting interesting results that don't track with expectations. Here are a few examples:
Folder Assigned Alias Expected Returned Alias Actual Returned Alias
C:\users\Chuck\Documents Docs /Docs /Default
C:\Users\Chuck\Documents\ Work Work /Work /Default/_Work
H:\Library - Software Soft /Soft H:\Library - Software
C:\Users\Chuck\Pictures Pics /Pics /hostpictures
H:\Library - Personal\School\Graduate School /School H:\Library - Personal\School\Graduate
What am I missing?
It appears that only built-in aliases are supported.
Not needed
and also didn’t look for the shortest alias.
It should match the deepest alias, I think. Not the shortest.
My bad, it's already the deepest :slightly_smiling_face:.
The built-in alias limitation is unfortunate. Request Resolve() be expanded to include user-created aliases.
User-created aliases will be supported in the next update.
