I configured my my tooltips quite nicely I think, so I often make use of the hidden / hard coded "CTRL + SHIFT + ALT + C" hotkey to get the full tooltip content into clipboard and save that into a "sidecar" file for various downloads e.g., but..
the default hotkey is hard to use (but can already be worked around it seems)
I need visible tooltip (automation no-no)
specific mouse position to make tooltip show up
no way to access multiple tooltips at once
creating the sidecar files cannot be automated
I found this in the docs for the Clipboard command:
So the aim is to write some metadata fields into another file, using info-tips as a way to define what gets written?
I would have the script build up the text itself without using into-tips, as that frees you from having to keep your info-tips looking a certain way everywhere just for one script.
Yes. The info tips configuration already is a somewhat nice central place to maintain what metadata is of interest. Leveraging or reusing it to some extend, is probably not the worst idea?! o)
Small use case demo:
To keep track of what file came from where, I create this *.meta.txt file for all the weird Linux executables I get from odd places e.g.. Then I put it onto the Linux box side by side to the downloaded file I already copied and renamed there, to reflect software version. The original file name, MOTW (download URL source / referrer from ADS) and time stamps get lost this way, but the *.meta.txt file will tell me in the future.
Currently, a script cannot reuse this info tip configuration I guess, so it would need to recreate the formatting and what properties / metadata to fetch and maybe also the grouping of file extensions (although I remember some file type group scripting functionality).
A major hurdle though, is the missing access of a script to values provided by other script columns. So scripts would need to be rewritten / refactored to make use of "@include" and expose relevant methods for metadata extraction.
Not an impossible task, but since the wanted info tip text is already there, in the desired form and function, I would think the idea of getting that as it is, is quite reasonable?
No need to invent things twice or overhaul a lot of existing scripts. Getting access to script column values from a script, would be nice to have some day as well of course, but for now, getting the info tip as it is, seems like a low hanging fruit? o)
Maybe that makes more sense to you now, not sure, will see! o)
I had to replace a "< bs>" tag appearing in the infotip text for an yet unknown reason with "\" (backslash), but no problem! o)
Now I can use my own hotkey, don't need to position the mouse, don't need to wait and I can also just get the InfoTip(s) right from the context menu, even for multiple items, very excellent! o):
