I have global filters set:
However, when I attempt to check the filter via the following script it returns a "false" indicator:
var filterSet = DOpus.filters.enable;
var globalFilterFlag
if (filterSet === "True")
globalFilterFlag = "True"
} else
globalFilterFlag = "False"
I would expect since the global filter box is checked that the filterSet would return "True". Is this not the case? If not, how do I get the proper indicator via script?
As always, thanks in advance!
