Hello,
since 13.4.1 Beta FOLDERCONTENT
with copy
or move
argument no longer copies or moves, instead the "Select Destination Folder"-dialog opens.
Hello,
with copy
or move
I also have a problem with FOLDERCONTENT
I've been using this button for years and now with beta 13.4.1 it no longer works
<?xml version="1.0"?>
<button backcol="none" display="both" label_pos="right" textcol="none" type="menu">
<label>Portable</label>
<icon1>/dopusdata/Icons\imageres241.ico,0</icon1>
<label>Programs</label>
<tip>Go to Programs</tip>
<icon1>C:\Windows\system32\imageres.dll,3</icon1>
<function type="normal">
<instruction>Go "C:\Program files" FOLDERCONTENT="maxdepth=2,filefilter=*.exe"</instruction>
</function>
</button>
</button>
Thanks! This should be working again when we put out 13.4.2.
