"Go FOLDERCONTENT" related problem
Dear Opus team!
I have it set up like i right click on a folder and there is a CONTENTS menu in the right click menu and it shows executables and video files. It shows "Launcher - Shortcut"
Clipboard Image (12)
Like in the example screenshot i right click the folder of the game im playing and i click the launcher shortcut and it should lunch the launcher of the game.
The behaviour right now is that it opens the folder and does not execute the .lnk (Launcher - Shortcut.lnk) pointing to the launcher like it was before even in the previous versions of the BETA or any versions before.
Here is a shot of the setup: (group: "10exe" consists of .exe and .lnk)
Im guessing it is a bug because it should launch the executable and not open the folder its contained in. Like in the shot below it just opens the folder and does not launch the executable like in previous versions. It should execute Launcher - Shortcut.lnk and open up the game.
Thank you for your feedback on this!
我也遇到了同样的问题
I also encountered the same problem
<?xml version="1.0"?>
<button backcol="none" display="icon" icon_size="large" textcol="none" type="menu">
	<label>Start Menu</label>
	<icon1>#gostartmenu</icon1>
	<button backcol="none" display="both" label_pos="right" textcol="none">
		<icon1>#newmenu</icon1>
		<function type="normal">
			<instruction>Go PATH /commonstartmenu/Programs|/start/Programs FOLDERCONTENT=nomenusel,useshell</instruction>
		</function>
	</button>
</button>
One option is a folder with a shortcut to the executable for each game.
Use this command in a button or context menu, substituting your path, to call up the list of your game shortcuts:
 Go "T:\Active\Files Shortcuts" FOLDERCONTENT
Unfortunately, this is currently broken in DO13.0.44 beta (opens the folder and doesn't run the executable). It will probably be fixed in the next beta update.
Thank you for the suggestion!
Yeah i will just patiently wait until its fixed, im just reporting it in case no one else notices it. It is just a convenience for me, nothing too serious.
Cheers!
That's fixed in the next beta. Thanks for reporting it.
