bet2003
#1
Hi.
I need to use the groub by type.
But I want to alter the group names, contents and its distrbution in the layout.
Is that possible?
lxp
#2
Yes. You need to set up a ScriptColumn:
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Scripting/ScriptColumn.htm
Here's an example you could modify:
