v13.2 windows 10 pro
Group by: 'none' - doesn't 'stick' on "this PC".
Works fine on all other folders
Go to Preferences / Folders / Folder Formats and edit the System Folders / This PC format to turn off grouping for it.
Look on the Grouping tab.
That’s set to group by type. Click the X in the right of the “group by” field to clear it if you don’t want to group by anything.
Thank you
