This is something I'm really missing from Magellan Explorer. I need to have two path bars, each one corresponding to a different pane in my commander-style setup. Is there any way I can do this?
I don't think there is a way to do this, but why would you want to? You can only type in one at a time, and if you click on the source or destination pane, the path in the path bar changes dynamically.
It's a feature found in other FMs like SS and Magellan. I want it for several reasons. It's slower to click a pane and then click the path bar than it is to simply click the path bar linked to the pane you're interesting in using. Also, I'd rather have the drop-down arrow for the left pane's path bar be towards the center of the screen rather than the right edge of the screen. I could fix that by putting some space fillers in the right half of the path bar, but I'd rather have two bars.
