HEIC Viewer
If you're on Windows 10 or Windows 11, Microsoft's HEIC codec works:
Those will also enable HEIC in the Windows Photos app and other software that uses WIC.
Lxp also mentions another alternative above:
I had to buy, but worth. THANK YOU!
I ended up buying the HEVC app from the Store, since the HEIF extensions said they were already installed, but weren't working. Previews appeared in Directory Opus immediately. Worth doing.
HEVC Video Extensions costs $1.45 now and HEIC files now work for me - thanks
