Yesderday I was able to open DOpus (latest version) and control right click to limit seeing this huge listing of context menu options. Now...when I opened a lister and selected an item (any item) and Ctrl right clicked on it...I got the huge list of menu choices. What's going on? Thanks.
Interesting... I don't ever recall there being an option to hold a key (like Ctrl) in order to suppress seeing items in the context menu. I thought we only had the option to reveal all the context menu items (i.e. SHIFT key) if you have the Hide Windows items on file context menus (shift overrides) option enabled... which is the reverse from the functionality you're saying you used to have.
Strangely enough that's what happened yesterday when I used DO. I hit the Ctrl button and right clicked the item and it suppressed the entire listing. Now...after reading your reply I immediately went to the menu selection option in Misc and enabled that option so now I have the best of both worlds.
