Hi - is there a way to force Help to display on top of Dopus? Can't see anything about this anywhere else. Currently Help is opening behind the screen and it's irritating having to move/resize the Dopus window in order to see and use Help.
If you´re on XP, you might have "pinning" active, causing the lister opening "always on top". If you turn that off, the help window should open on top level.
Hi - no, Vista 64, so pinning isn't available. ANyway as DOpus follows normal procedure as far as other windows go it's not a pinning issue - it's just the Help window that gets stuck behind it as though it WERE pinned. Am I the only one??
